Could not read data from the virtual disk | VM backup failing
  • October 13, 2022
  • 8 replies
  • 3635 views
Forum|alt.badge.img+2
Dear All,
Please help resolve below incident. If you can please explain this.
BR
Best answer by Jos Meijer
Right click the instance within the hypervisor cliënt, select properties and go to access node tab to view assigned nodes and frel.
Or check the proxy column shown in your printscreen.
Sunil Turakani
Looks to be an error coming from VDDK library. Can you check the VDDK logs (vixdisklib.log) to get more info.
  • October 13, 2022
Dear Sunil,
VDDK logs (vixdisklib.log) in a MA?
Sunil Turakani
check on VSA proxy host.
  • October 13, 2022
How to find VSA proxy host in environment?
Jos Meijer
Forum|alt.badge.img+21
  • Community All Star
  • October 13, 2022
Shaun Hunt
  • October 14, 2022
Hi Abhiman,
Out of interest what Service Pack / Feature Release version are you running on?
Shaun
Onno van den Berg
Forum|alt.badge.img+24
Luckily @Jos Meijer seems to have the right crystal ball as he was the one giving the correct solution…..
Forum|alt.badge.img+9
  • February 2, 2023
Question: we have a backup job that before failed and the error was Could not read data from the virtual disk.
The backup job took 40 hours before it failed.
Is there anything in the active job that will tell me the backup job will fail again with the error Could not read data from the virtual disk ?
