Crazy Slow Hyper-V Snapshots
  • April 30, 2025
  • 132 views
   We are in the unfortunate process of migrating from VMware to Hyper-V.   We are in mid migration and I am finding that the snapshots are taking longer and longer.   Normally snaps are about 15 to 30 min.   Now they are taking over 5 hours for a quiesced  snapshot.  After the snapshot is done, the Backup Copy runs quickly.
   During the Snapshot job, I see lots of log messages about CHyperVInfo2::RunParallelVMSnapshotTask() - No available thread found for creating software snapshot of virtual machine XXXXXXXX.
   I can not find any setting for the number of threads that Commvault will use to talk to Hyper-V.   I have had a support call open for a bit but not felling like it is making any progress.   This feels like it should be a 101 type question.
   Does anyone else have delays with their Hyper-V snapshots?
Sureshkumar S
Hi ​@Farmer92 ,
Good day!
Try to use the below key and see if it helps
https://documentation.commvault.com/additionalsetting/hypervsnapthreadcount.html
Sureshkumar S
  • May 1, 2025
Sureshkumar,
   Thank you support did just point out that key this morning as well.   I had seen the key when I was looking for the solution, but the documentation says it is for crash consistent backups.   We are taking quiesced backups… I am going to try the key, but not sure if it will help based on the description.
Thank you,
  • May 2, 2025
Looks like the description might be correct.  It is only for cash consistent backups.   I did have the additional setting in place last night, and it did not help.
