Creating pseudo-client for RHEV (http vs https) - fix for SP20
  • October 25, 2022
  • 65 views
Hello Commvault Community,
I create a new topic because I don’t know if I will get an answer - it has already been resolved.
Same topic as here, but for SP20:
There is a logon failure during configuring the Red Hat Virtualization pseudo client.
Client proxy connects to olvm manager via http. The latest version of the manager doesn;t support such a connection.
You have the opportunity to find out if such a patch is available for SP20 or if we need to write to Commvault support to write such a fix for SP20.
Thanks&Regards,
Kamil
Best answer by Mike Struening
Looks like a backport has been requested for 11.20!
Hi @Kamil , thanks for the post (and the link)!
I found the form ID (Form 2340) though the details (under 11.20) say it is not needed.
If you’re seeing the same issue, please open a support case and reference both of these threads, as well as Form 2340.
Once you do, share the case number here so I can track it 🤓
  • October 26, 2022
Hello @Mike Struening ,
Thank you for your quick response as usual and suggestions on what to do next - I escalated the problem to CV support, according to your suggestion.
Incident 221026-215
Kamil
  • November 3, 2022
@Mike Struening
Yes, that's right. Thank you for keeping track of my thread.
Kind Regards,
Kamil
🤣 All good, it’s what I do (amongst many other hats)!
