decomm backup for vCenter
  • September 7, 2023
  • 91 views
We are planned to powdered off the vCenter. before doing power it off planning to take decommissioned backup, please suggest can we take entire VMs hosted in the vCenter or all folders or only selecting vCenter. please suggest
Best answer by Rajiv
Hello @ManiD
I believe you are trying to take backup of vCenter before decommissioning it?
Please take a look at this document once: https://documentation.commvault.com/2023e/expert/32029_protecting_and_recovering_vcenter_server.html , it should help.
Best,
Rajiv Singal
Forum|alt.badge.img+5
Hi @ManiD ,
When the vCenter is running on a virtual machine, you can use an application consistent backup using the VSA to protect the virtual machine as well as the vCenter database and files. I would also suggest taking a final backup of VMs hosted on the vCenter as well, as it will give you an opportunity to perform restoration for individual VMs.
Keshika Bisht
Rajiv
  • September 8, 2023
Hello @ManiD
Best,
Rajiv Singal
  • September 11, 2023
Thank you @Rajiv @Keshika Bisht for your support.
