we are planning to install an Azure Stack HCI 23H2 cluster.
Does CV (11.28) currently support this version for Backup and Recovery? I find in the documentation “Azure Stack HCI version 20H2 and more recent versions”.
Thanks in advance.
Jörg
Thanks in advance.
Jörg
Best answer by Joerg Paukner
here an update after my installation of two ASHCI 23h2 cluster and a long story of ticketing with the support.
The ASHCI 23H2 activate the WDAC policy in Enforce mode. This will block all installation, because the installation package is not signed.
The solution:
The backup will run.
The complete steps is find here in the MS article.
The root cause of the issue I have found on a Veeam ticket. So I think, there is a little bit to do on CV side for the complete compatibility sentence.
With best regards,
Jörg
