Excluding RDM disks in OLVM
  • January 12, 2024
  • 417 views
Hi all!
I’ve been trying to solve some issue, but I’m out of ideas already. I’m preparing new Commvault solution for OLVM (Oracle Linux Virtualization, based on oVirt). One of the VMs (let’s name it VM_RDM) has physical RDM disks attached, which are being backed up externally, outside of CV. I need to exclude them from CV backup, but sadly I didn’t find any solution for OLVM.
My VM_RDM is backing up properly, but I’m getting status “Backed up with 1/more errors” with description “physical RDM disks are not supported”. I know it doesn’t impact my backups, but is there any way to get rid of this communicate? I can’t use filesystem backup due to requirements. I tried disk filters in “content” page, setting up different plans, subclients etc, but it just doesn’t work. I tried additional setting “IgnoreUnsupportedDisks” (https://documentation.commvault.com/additionalsetting/details?name=%22IgnoreUnsupportedDisks%22&id=1318), but it didn’t change anything as well.
 I found this topic which indicates the same problem:
Has anything changed since then?
MichaelCapon
  • January 12, 2024
Hi @TomasCV
Can you confirm what Software version you are currently using please?
Michael
  • January 15, 2024
Hey @MichaelCapon, I use CommCell 11.32.28 and “Commvault Backup&Recovery for VM” license.
