failed to get access token.connection failed
  • February 8, 2022
  • 1238 views
hi,
I'm trying to restore VM to AZURE and then I get the following message, anyone know maybe why?
Best answer by liorkrispin
hi
the problem was solved  - Azure Keyvault was configured with specified networks that can access to the Keyvault , after changed it to allow all  networks the backup job started to work
Chris Hollis
  • February 9, 2022
Hi @liorkrispin
Have restores ever worked or is this the first time you’ve tried?
Just like your other community question, are you able to check / share some of the output from the vsbkp.log so we can see what exceptions are being reported?
Its either account specific or the proxy isn’t meeting our requirements - https://documentation.commvault.com/11.24/expert/3319_system_requirements_for_virtual_server_agent_with_microsoft_azure.html
Chris
  • February 13, 2022
hi Chris,
i cannot find the vsbkp.log file…
@liorkrispin , check the Media Agent/Proxy itself.
Conversely, you can right-click the job and select Send Logs, then pick a local drive to review them.
  • February 15, 2022
hi
Glad to hear it, and thanks for sharing with us!
