We want to migrate VMs from Vmware to Hyper-V using Commvault. The Hyper-V will be a cluster with SAN storage to store the Cluster files. The Hyper-V cluster will be hardened with Windows Firewall rules. What are the ports to be allowed for allowing Restore of VM from VMware to Hyper-V and Backups of Hyper-V VMs on Proxy.
Firewall Ports for Hyper-V Backup & Restore
Best answer by Damian Andre
Hyper-V relies heavily on WMI - but that should be local communication with the installed agent and the WMI destination. I do not believe we traverse the network to perform WMI queries if you have a Virtual server agent installed on all nodes.
