Help Error Code: [62:306]
  • March 30, 2022
  • 166 views
Forum|alt.badge.img+5
I need help, all my jobs are failing with the same error below.
Best answer by Mike Struening
@marcelo bernardes fernandes , this is usually an issue with the destination library.
Where is this job writing to?  Can you look for errors on the OS/Library side?
