How to integrate Nutanix cluster in commcell console
Dear all,
We are new with Nutanix, and company has the need of integrating Nutanix 7 with our commvault platform. We are using 11.32 and base on documentation it’s supported.
Our concern is whats the component that we have to add during the integration?
  • Prism Central IP
  • Prism Element IP (nutanix node)
Base on all the documents we have read we still have many doubts. Even after watchign these video:
Commvault v11 - Nutanix AHV support preview
Any help is welcome.
Patricio
Alex Deaconu
That is quite an old video. My advice is to use the Command Center, when adding any kind of hypervisor.
https://documentation.commvault.com/2023e/software/configuring_backups_for_nutanix_ahv.html
  • October 9, 2025
Hi Alex,
Thanks for your answer. There is kind of confusion when adding Nutanix… We’ve tried to add Prism Central, but as we understood we should add the Prism Element (nutanix server).
Patricio
  • October 15, 2025
Unfortunately, Nutanix hypervisor client created with Prism Central IP/FQDN is currently not supported. You have to use Prism Element Cluster IP.
https://documentation.commvault.com/11.40/software/configuring_backups_for_nutanix_ahv.html
  1. Provide a fully qualified hostname or IP address for the Prism Element.
