How to set VM filters via CLI for Backupset or Subclient
  • October 24, 2023
  • 119 views
Forum|alt.badge.img+2
Hello All.  We have 4700 VMs with a couple dozen backups sets where I need to exclude VMs that don't require a backup.  e.g. AD, DNS, VDI, etc.  I know I can manually open each backupset and create a VM Filter, but I'm thinking there's a better way.
It would be great to have a "global filter" for VMs similar to WinFS and LinuxFS clients.
Is there a way to utilize PowerShell or CV CLI?
Or is there some other way I’m not thinking and I’m making this harder than it needs to be?
Dan
PS after typing this I'm thinking I should have less backupsets…  but still interested in your thoughts.  :)
Best answer by Rajiv
Hello @dgzagm4q4cv
Could you please check this document and let me know if it helps? https://documentation.commvault.com/2023e/expert/32408_defining_filters_for_backup_set_vmware_command_line.html
Note: Please test it once on non production client before running directly on production sub client/backup set.
Best,
Rajiv Singal
Rajiv
  • October 25, 2023
Hello @dgzagm4q4cv
Best,
Rajiv Singal
  • October 25, 2023
Thank you.  This is good stuff.
  • October 26, 2023
Hi @dgzagm4q4cv
maybe it is also possible for you to use VM Tags in the vCenter (in case of Vmware) and filter VMs with this Tag assigned.
That can help in case of a certain dynamic on the VM side and avoids updating you (backupset) filters every time VMs are deleted or new VMs have to be added
rgds
Klaus
