How VM snapshot is created?
  • March 7, 2023
  • 1568 views
Who is the snapshot requestor?
Who is the writer?
Best answer by MichaelCapon
Hi Arvind,
For VMware backups Commvault is dependent upon the vCenter for the Snapshot operations to be performed (The Action is performed by VMware).  The Commvault VSA Proxy simply sends the request to the vCenter to create the VM Snapshot for the backup. It will also send the request to Delete the Snapshot once the VM backup has been completed.
When a Commvault requested snapshot is present on a VM, you will be able to see it in vCenter like any other snapshot. You may see a snapshot name with _GX_BACKUP_ and a description with the JobID.
Hope this helps, If you need anything specific please let us know.
Michael
MichaelCapon
  • March 7, 2023
Hi Arvind,
Michael
Hi Michael,
Thanks for your reply. Is there any document which helps in understanding the complete process?
christopherlecky
Challenger
Forum|alt.badge.img+16
Yes, but they are part of the commvault training package not publicly available.
