Hyper-V Data Reader -> AuxCopy streams translation
  • November 30, 2021
  • 43 views
Hi all,
one short question regarding hyper-v data reader and auxcopy to tape.
When i´m using 10 Data readers during the vsa backup job and i would like to copy this job to tape did commvault user 1 Stream because its only one backup job or did commvault use 10 streams for the auxcopy.
As i know for vmware i must take the vsa v2 agent to get multi streams for auxcopy but regarding hyper-v
maybe you can give me an quick hint.
Best answer by Mike Struening
Hi @SSchmidt !
Are you looking to get a result of 1 or 10?  You can combine streams on the Aux copy to get to 1, if you are getting 10 on the Aux.
Hi @SSchmidt !
