Incorrect transport mode selected
  • Mar 14, 2024 11:45 AM UTC
  • 277 views
Hi Team,
Backup failing with error “Error opening the disks for virtual machine [up0022alli_UCS_Central]. Verify that the correct transport mode is selected.”
Initially Transport mode was: NBD. It will fail sometime, but will get completed using the same transport mode.
Later changed it to Auto: Again its using NBD. Similarly sometimes failing sometimes completing.
HI @Suryavamsi ,
Can you check vsbkp.log on VSA and see why it fails?
Or you can log a case with Support and we will check.
Sebastien
Forum|alt.badge.img+2
  • Jan 20, 2025 2:29 PM UTC
Any update on this issue?
Rajiv
  • Jan 21, 2025 10:36 AM UTC
Hello ​@jxb are you facing the same issue? Can you share the logs or raise a case?
Best,
Rajiv Singal
