Intellisnap problem
  • January 24, 2022
  • 9 replies
  • 775 views
HI teams,
On two distinct datacenter, we have one media agent and  one Hpe Primera
On intellisnap backup on a Vmware backupset in  DC2 it failed while in DC2 it goes correctly.
in below the configuration for LSI2 ( the same on LSI1 )
Subclient Configuration - Tab Intellisnap opertaion
Subclient Configuration - Tab Advanced option
The error :
Error Code: [19:599]
Description: Loss of control process vsdisc.exe. Possible causes: 1. The control process has unexpectedly died. Check crash dump or core file. 2. The communication to the control process machine Vcenter might have gone down due to network errors. 3. If the machine Vcenter is a cluster, it may have failed over. 4. The machine Vcenter may have rebooted.
No Firewall, no rules,.
DNS is OK
Thanks for your help
Best answer by R Anwar
Hi @virgil
Open Commvault process before backup starts and see under processes if vdisc is spawned once backup is started.
Also, check the MA OS events to see process crash logging.
MichaelCapon
  • January 24, 2022
Hi @virgil ,
Can you check the vsdiscovery.log on the VSA Proxy (Media Agent) here? - do you see any communication failures or process crash at all?
Michael
  • January 24, 2022
Hi Michael
No vsdiscovery.log on this MA…. forget to install module ?
regards
@virgil , can you confirm what is installed on both nodes?  It could be a lack o0f installed module, or just that the process (and therefore logs) are not getting started,
  • January 25, 2022
Hi Mike,
The two nodes are similar.
Services on NODE2
Installed Software on Node2
R Anwar
  • January 25, 2022
Hi @virgil
  • January 26, 2022
HI teams
vdisc doesn’t  start when i lauch backup…
no info in windows event logs
regards
  • January 26, 2022
on below the backup log
Machine : w36p0001
File    : JobManager.log
11040 6908  01/26 15:54:13 102140 AppManager Found proxy clients on VSA subclient [3496] with SP20 or higher service packs.
11040 6908  01/26 15:54:13 102140 JobSvr Obj TargetMediaAgent [W36P0041.domain.local]
11040 6908  01/26 15:54:14 102140 Servant    [---- IMMEDIATE SNAPBACKUP REQUEST ----], taskid [12541] Clnt[Vcenter] AppType[Virtual Server][106] BkpSet[defaultBackupSet] SubClnt[LSI2_Test] BkpLevel[Full][1]
11040 4064  01/26 15:54:14 102140 Scheduler  Starting jobs only on proxies with service pack SP20 or higher
11040 4064  01/26 15:54:14 ###### Resetting the cache for the backupsetGUID[C9ADA428-4AF2-4E1E-9CED-369DCAB26E75] as ttl minutes elapsed.
11040 6efc  01/26 15:54:15 102140 Scheduler  Phase [2-Discover] (0,0) started on [W36P0041.domain.local] in [0] second(s) - vsdisc.exe -j 102140 -a 2:3496 -d W36P0041.domain.local*w36p0041*8400 -t 1 -ref 0 -i 2 -snap  -jt 102140:2:1:0:49049
Machine : w36p0001
File    : Licensing.log
11040 6908  01/26 15:54:13 102140 Check license: appType [106] Name [Virtual Server] on client/library [7]- Valid
11040 6908  01/26 15:54:13 ###### License - Type [196] Name [NetApp Snap Management]: Free permanent license available.
11040 6908  01/26 15:54:13 ###### License - Type [196] Name [NetApp Snap Management]: available [1000000] used [0]
11040 6908  01/26 15:54:13 ###### [1000000] perm license [NetApp Snap Management (196)] are issued
11040 6908  01/26 15:54:13 ###### License [Hardware Snapshot Enabler (163)] appType [1092] on client [7] is Valid
11040 6908  01/26 15:54:16 ###### License - Type [196] Name [NetApp Snap Management]: Free permanent license available.
11040 6908  01/26 15:54:16 ###### License - Type [196] Name [NetApp Snap Management]: available [1000000] used [0]
11040 6908  01/26 15:54:16 ###### [1000000] perm license [NetApp Snap Management (196)] are issued
@virgil , are you still having this issue?    I would suggest opening a support case to have this looked at.
Can you share the case number with me?
@virgil , I’m closing this thread off, though please update it if the issue continues so we can assist!
