Issue comunication commvault VS fusioncompute 2023E
  • Dec 6, 2024 7:33 PM UTC
  • 74 views
 Browse failed for : https://192.167.26.15:8443/OmsPortal/#/login Reason : Failed to connect to virtual machine host [https://192.167.26.15:8443/OmsPortal/#/login] as user [admin] from access node [consola2-he]. Please ensure that the access node is able to communicate with the host and that the user account and password are correct.
  1. On the access node (consola2-he) can you telnet or open a connection to 192.167.26.15:8443 ? can you use a browser or lynx to access https://192.167.26.15:8443/OmsPortal/#/login
  2. Additional details will be in vsdiscovery.log on consola2-he
  3. Are you sure the IP address correct ? 192.167.26.15 instead of 192.168.26.15?
Gracias por su respuesta. La prueba se realizó a través de telnet y fue exitosa. También tengo acceso a través de la web. Las credenciales que tengo también son correctas y la dirección IP que estoy ingresando es correcta.
Espero contar con su apoyo.
Saludos.
Thank you for your reply. The test was performed via telnet and was successful. I also have access via the web. The credentials I have are also correct, and the IP address I am entering is correct.
I look forward to your support.
Best regards.
