Kafka backup with Commvault
  • April 27, 2023
  • 609 views
Is there a solution or recommendation on how to backup / restore Kafka with Comvmault?
Mike
(Please move this question to “Commvault Q&A”)
Forum|alt.badge.img+18
  • April 28, 2023
We do not have an agent for Kafka.  If it is housed on a VM you could use the Virtual Server agent or a file system agent to protect the data itself. Depending on what underlying database technology that it uses, you may want to look at using an agent for that database management system.
  • May 30, 2024
is there a way to backup it ?
what db client am i suppose to install?
  • June 20, 2024
What exactly do you want to backup?
Kafka is a streaming platform, which keeps persistent data in other things, like S3 buckets or RDBMS’s.
You need to protect that persistent data. But the ephemeral VM / container that is running Kafka could be protected with general VSA backups.
