Merge Duplicate VM Clients
  • June 21, 2022
  • 1854 views
Hi Team, I try to merge the duplicate Client but encounter this error. is there i need to manually rename the backupset for each client?
Best answer by Gseibak
Hi Raj -  what version of Commvault software are you on?
Handling VM Clients That Cannot Be Merged Because They Have the Same Parent Backup Set:
If duplicate VM clients cannot be merged, the backup history for the original VM client includes older jobs, and the backup history for the duplicate VM client (such as client_name_1) has newer jobs.
To merge VM clients that cannot be merged automatically, perform the following steps:
Wait until the jobs for the original VM client have been pruned as part of data aging. Delete the original VM client. Rename the newer VM client by removing the '_1' from the client name. After you perform these steps, subsequent backup jobs are associated with the newer VM client.
  • June 21, 2022
  • July 18, 2022
Hi @Gseibak , will that then mean that the older jobs will thereafter be associated with the “newer client” as well?
