Need Help with cloning subclient xml file
  • December 1, 2021
  • 114 views
Forum|alt.badge.img+8
Hello Guys,
appreciate if you could help me filling the xml file as im not good with xmls
i’m migrating 300+ subclients from old vcsa to a new one
i’ve used the below xml file however, i dont know where i can put the destination vcenter ?
what other values should be filled in vm subclient cloning.
<App_CloneSubClientRequest>
<cloneEntity>
<test1/>
<defaultBackupSet/>
<VMware/>
<Virtual Server/>
<vcenter-01/>
</cloneEntity>
<subClientProperties>
<subClientEntity>
<test1/>
</subClientEntity>
<content>
<path/>
</content>
<vmContent>
<children equalsOrNotEquals="1" name="test1" displayName="test1" type=""/>
 </vmContent>
</subClientProperties>
</App_CloneSubClientRequest>
Thank you!
Best answer by Mike Struening
Good question, and welcome to the community!
I’m checking the docs and do not see that as a possible input for App_CloneSubClientRequest:
https://documentation.commvault.com/11.25/essential/106075_rest_api_post_clone_subclient.html
with that in mind, we DO have a Workflow that will copy all of the config details here:
https://documentation.commvault.com/11.25/expert/139052_migration_of_virtualization_clients_to_indexing_version_2.html
This might be just what you need.
Let me know if there’s any questions you have about this!
Thank you Mike  ! i didnt know about that workflow.
it did the job perfectly, the job took 18hours and that was so long but it did migrated 740 subclient successfully.
thank you again it was such a great step to join the community =)
Glad to hear it, on both counts!
The community honestly grows better and better everyday thanks to people just like you, coming to share and learn.
Looking forward to the next time I see you!
