Nutanix AHV Backup Failure – Access Node Unable to Mount NFS Share After Nutanix Firmware Upgrade
  • August 31, 2026
  • 26 views
Dear Commvault Support Team,
We are facing an issue with the Nutanix AHV VM backups for the ***S02 environment.
The backup jobs were working successfully for the past approximately two years using the same Commvault Access Node. However, the issue started occurring approximately two days ago, following a firmware upgrade performed on the ***S02 Nutanix host/cluster.
Environment Details
  • Commvault Version: [11.44]
Issue Description
The same Access Node has been successfully taking backups for both ***S01 and ****CS02 for the past two years.
Currently, backups for ***CS01 are running successfully, whereas backups for ****S02 are failing.
The backup job fails before processing the VM disks with the following error:
We also observed the following error in the Commvault logs:
Troubleshooting Performed
  1. Verified that the hostname resolves to IP.
  2. Verified connectivity from the same Access Node to the Nutanix environment.
  3. Verified that the same Access Node is successfully backing up the***S01 Nutanix environment.
  4. Verified VM browsing from the Commvault subclient. We are able to browse and discover the VMs under ***S02.
  5. Verified Prism connectivity on port 9440.
  6. Customer confirmed that no IP addresses are currently configured in the Nutanix Prism Element Filesystem Allowlist.
  7. The customer confirmed that a firmware upgrade was performed on the ***S02 environment approximately two days ago, which coincides with the start of the backup failures.
  8. We reviewed a similar issue reported in the Commvault Community where removing the Access Node IP from the Nutanix Filesystem Allowlist resolved the NFS mount issue. However, in our environment, the customer has confirmed that the Filesystem Allowlist is empty.
Request for Commvault Support
Kindly assist us in investigating why the Access Node is unable to mount the NFS share from ****CS02 after the recent Nutanix firmware upgrade.
As the same Access Node and backup configuration are working successfully for ****CS01, we would like Commvault Support to review whether there are any compatibility issues or changes required after the Nutanix upgrade.
Please let us know the required logs and any additional troubleshooting steps
Hi ​@vallapu umesh ,
Kindy make sure you don’t include Personal Identifiable Information (PII) like hostnames and IPs on public community posts,
Regarding the issue, you did pretty good troubleshooting but you missed to check port 111 as per the error message,
please use cvping from the access node to Nutanix CVM-IP (NFS server) ~ “**cpcs02” on ports 111, and 2049
Also, please try to add the access node on Nutanix whitelist
  • September 1, 2026
Dear ​@AbdulRahman AlSindiony,
Thanks for your Suggestions,
As we have validated 111 port earlier not working from the access node to the Nutanix AHV,
We checked the connectivity between the Access Node and Nutanix with 111 ports after removing the access node IP from Nutanix Filesystem Allowlist/Whitelist ***PCS02 111 working fine.
the backup is complete successfully.
We need the clarification how it solved After removing the Ip from the Nutanix Filesystem Allowlist/Whitelist
@vallapu umesh ,
This is a great question to Nutanix support, why connection from the access node to the CVM-IP address was failing previously and worked after adding it to the whitelist.
I believe they would say you need to whitelist any machine trying to communicate with Nutanix NFS containers there, but I would love to hear their answer.
Abdu
  • September 2, 2026
@AbdulRahman AlSindiony ,
Earlier access node ip is in whitelisted from Nutanix end. the issue was cleared after removing the Access node Ip from Nutanix Filesystem Allowlist/Whitelist ***PCS02 later port 111 working fine. and backup job is completed
