Nutanix VM streaming backups failing with Mount issues
  • December 29, 2021
  • 1262 views
Ananth
Hello All,
I have configured the Nutanix VM streaming backups by using the Hyperscale nodes as VSA proxy. The backup got failed with below error:
7717 1e71 12/29 16:46:56 104 CNutanixInfo::_MountVM_Streaming() - Mounting Disk [scsi-0] [f87c9f9b-e15f-4e13-afde-cbc18af752bd] fileName [/SPIProduction/.snapshot/98/6993716522296088412-1603969612779858-74798/.acropolis/vmdisk/f87c9f9b-e15f-4e13-afde-cbc18af752bd] 7717 1e71 12/29 16:46:59 104 CNFSMounter::_Mount_Unix() - failed to run mount command [timeout 30 mount -t nfs -o vers=3,ro,soft,retrans=5,timeo=600 XX.XX.XX.X:/SPIProduction /opt/commvault/ProductionData/VSA_NFSMountPoint/7717/10.94.10.5__SPIProduction] - Error: mount.nfs: access denied by server while mounting XX.XX.XX.X:/SPIProduction 7717 1e71 12/29 16:46:59 104 CNutanixInfo::_MountVM_Streaming() - Failed to mount XX.XX.XX.X:/SPIProduction
As per documentation these are the system requirements for the VSA
  • VSA proxies must have access to NFS exports from the NFS server.
  • The proxy machine must be able to access the NFS ports for the destination NFS server behind any firewall configuration.
  • When running as root, libnfs tries to allocate a system port for its connection to the NFS server. When running as non-root, libnfs uses a normal ephemeral port. By default, many NFS servers do not allow non-system ports to connect. For these NFS servers, you must use the "insecure" export option in /etc/exports to allow libnfs clients to connect
Hence I would like to know whether the mount issue is at HSX VSA node and do we need to provide any additional permissions?
Network communications are all good between the CS, BLOCK and Nutanix cluster.
Regards
Ananth
Best answer by MichaelCapon
Hi @Ananth ,
What account are you using for the backups here? If not “admin”, has the user been configured as an Cluster Admin in SSP?
Did you add the Hyperscale X Node’s IP/Subnet to the NFS Whitelist on the Nutanix environment?
Example steps can be found here: https://portal.nutanix.com/page/documents/details/?targetId=Web-Console-Guide-Prism-v55:wc-system-filesystem-whitelists-wc-t.html
From ncli: ncli cluster add-to-nfs-whitelist  ip-subnet-masks=IP_ADDR/SUBNET
Have you tested a manual mount on Hyperscale X Node of the NFS share XX.XX.XX.X:/SPIProduction?
Michael
MichaelCapon
  • December 29, 2021
Hi @Ananth ,
Michael
Ananth
  • December 29, 2021
Hello @MichaelCapon ,
Thanks for the quick response.
We are using the admin account.
Let me check whether the IP’s are whitelisted.
Yes we tried manual mount, it has not reported any errors or didn't prompt for credentials as well however post the manual mount we cant see the mounted share shown in node.
Ananth
