OLVM/RHV restore parameters
  • May 19, 2026
  • 9 replies
  • 125 views
Hi All,
I’m running 11.40.42 version and while restoring VM to OLVM 4.4.10.7 (RHV) I’ve encounter two issues:
  • target VLAN has not been set correctly. Orginal VLAN has been preserved.
  • cross-hypervisor restore failed due to problems with attaching disk to VM. It looks like new VM does have Other OS type set instead of Oracle Linux which prevents attaching disk in SCSI mode. I’ve set additional attribute to not delete disk after failed restore and was able to create VM, attach disk and start VM
I’m wondering if those two issues are releated and commvault has problems with restoring proper metadata? Anyone encounter similar issues?
  1.
Sureshkumar S
Hi ​@pacynka ,
Good day!
Can you please update on the source hypervisor.
I couldn't see the cross restore ability to OLVM is not supported except from OVM
https://documentation.commvault.com/11.40/software/cross_hypervisor_restores_virtual_machine_conversion.html
Sureshkumar S
  • May 20, 2026
you are correct, source hypervisor (for issue 2) is OVM with Oracle Linux 6 as source VM. Issue with changing VLAN was related to out-of-place restore on OLVM only.
  1.
Sureshkumar S
Hi ​@pacynka ,
On the OOP restore try to select network option during restore and select the VLAN
https://documentation.commvault.com/11.40/software/restoring_full_red_hat_virtualization_rhev_vms.html#:~:text=Network%3A%20Select%20a%20network%20connection%20that%20is%20available%20at%20the%20destination%2C%20or%20select%20Automatic.
Regarding the cross restore we need to review logs and source machine config | can you raise a case ?
Sureshkumar S
  • May 20, 2026
This is the option I’m reffering to. Setting network connetion does nothing, and restore preserve orginal VLAN settings.
As for cross restore - this is PoC environment so we would need to go via CommVault Pre-sales team not support directly.
  1.
Sureshkumar S
hi ​@pacynka
Can you share logs of both jobs ?
Vsrst ?
Sureshkumar S
  • May 20, 2026
​@Sureshkumar S  I’ve shared link to logs in private message, but we can continue discussion here so community will benefit from finds. Thanks in advance.
  1.
Sureshkumar S
Hi ​@pacynka ,
Good day!
I missed the logs (Link is expirted now )can you please reshare it ?
Sureshkumar S
Sureshkumar S
Hi ​@pacynka ,
I have pinged you privately on the findings
Regarding the cross restore i could see the OS supported is Oracle Enterprise Linux 7.x, 8.x. there could be issue as we are trying to restore oracle linux 6. can you try conversion with latest OS ?
https://documentation.commvault.com/11.40/software/converting_to_red_hat_virtualization.html
Sureshkumar S
  • June 22, 2026
Hi ​@Sureshkumar S
haven’t caught that. After manually setting the OS VM has successfully started. We will take version into consideration in future migration.
  1.
