FR 11.32 A FREL.ova needs to be deployed via CommandCenter. documentation:
Configuring Deployment of the VMware Image in an Offline CommCell Environment
Save the Access Node and MediaAgent (FREL) OVA file directly on your primary access node as defined on the Hypervisor client within its configuration tab.
Does a possibility exist e.g. a key that I can deploy from another access node than the primary?
I know the several other methods to deploy and we cuurently try to change the primary access node but this is not the goal.
Thanks in advance
Joerg
