OVF Properties backup
  • October 12, 2021
  • 171 views
OVF Properties backup possibility in commvault?
Best answer by Gopinath
Currently, OVF properties are not protected which are part of vApp Options enabled VMs.
It is in road map for Future Release, mostly will be out by end of this year.
Regards
Gopinath
Hello!  I’m looking into this for you.
In the meantime, let me know if you want me to change your username!
  • October 12, 2021
Hello @OVF Properties backup
Are you looking to backup an OVF template with properties or a VM that was deployed using an OVF?
Can you provide a bit more detail on what you are looking for?
We are able to backup VM templates as per this doc Backups for VMware (commvault.com)
Forum|alt.badge.img+8
  • October 12, 2021
Regards
Gopinath
