Answer
OVM migration or cross platform conversion to vsphere
  • September 16, 2022
  • 470 views
Customer/Partner needs to migrate Oracle VM (OVM )  from Oracle VM to Vsphere ESXi.
1. Since Commvault doesn’t support cross platform conversion from OVM to Vsphere , can we take the full filesystem + system state backup of the OVM ( not vm image or intelligent snap ) and use virtualize me option to restore it to Vsphere ?
2.  When we use virtualize me option to take backup do I need to take one single full backup as a single Job, or can we take a Full backup earlier ( few days before ) and take a incremental backup on the  actual day of cut over and execute the restore. Does virtualize me supports a full + incremental backup taken by two separate backup job in different time to allow restoration .
If yes this will help us to take a full backup earlier and use a quick incremental backup to reduce migration time at the actual cut over day.
Best answer by Jos Meijer
Hi @lawysy
Yes, you need a file system agent backup with system state, but based on the 1-Touch Backup method.
As far as I know there are no limitations to Full backup only, you should be fine with full and incremental in a cycle. Not sure though if existing Synthetic Full's will cause issues when 1-Touch Recovery is enabled afterwards.
I would personally enable 1-Touch Recovery, make a full backup and let the schedule perform the next backups. Then perform a test P2V restore
Jos Meijer
Forum|alt.badge.img+16
  • Community All Star
Hi @lawysy
@Jos Meijer ,
Thanks for your timely reply and have a good day and weekend.
Jos Meijer
Your welcome @lawysy
Have a great day 🙂
