P2V SQL Cluster
  • June 7, 2023
  • 135 views
Hello Community
After restoring a physical SQL server that is apart of a always on cluster to a vmWare VM the mount points did not work.
The disks were restored in an offline state and could be brought online manually.
However when using powershell to list the disks of the server it only found 1 disk.
So the question is whether or not it is possible to use P2V to restore a SQL cluster?
Forum|alt.badge.img+18
  • June 14, 2023
Good morning.  Are the clustered volumes accessible to the virtualized nodes?
  • June 27, 2023
Yes they are.
We even tried adding a new disk to the VM  and that was bot visible either.
