Pre / Post scripts for vMware backups
  • May 7, 2023
  • 336 views
Forum|alt.badge.img+9
Is there an option to run a custom pre backup scripts for vmware backups ( not pre-freeze & post thaw ),
For instance a script that checks if a certain file exists on the discovered VM’s and only then allow the snapshot to be taken and start the backup process ?
PedroRocha
Explorer
  • May 8, 2023
I believe you could accomplish that creating a workflow to run a script that does that checking and if desired, run the backup process.
Pedro
Onno van den Berg
Forum|alt.badge.img+24
@TNO I have asked for the same thing in the past and if I recall correctly I also opened a CMR for it, however there is little to no chance that they will actually realize this. I would recommend to address this by a script that starts the backup from the script that communicates to the RestAPI (via the SDK) or via a workflow.
