Proxmox backup failed at nfs and ceph environment.
I created commserv 11.36.49 environment
Proxmox VE 8.3.5 datastore are 3 types, zfs, NFS share, ceph
I tried backup , zfs success, but NFS and ceph are failed
document said follwoing… I don't know why it failed
The Commvault software supports protection of Proxmox VE VMs with the following storage types:
NFS and ceph are output same error to /var/log/commvault/Log_Files/vsbkp.log , “ Failed to open device [/dev/nbd??]”
proxmox snapshot ware created, but commvault could not detected snapshot.
What could be the problem?
proxmox infromation
root@pve3:~# /opt/commvault/Base64/TestVMInfo -proxmox -server localhost -user root -password <password> -gethostinfo
Using NodeName=[] InstanceName=[Instance001]
TestVMInfo started...
BUILD-TIME=[02:16:28] BUILD-DATE=[Mar 15 2025]
Testing VMInfo Instance Type Proxmox
localhost 8.3.5
Host List:
Host=[pve3] Version=[]
VM: linux2-ceph GUID: 103_37f0d81e-3ed1-417a-9a10-3d8f556e3b37 Host: pve3
VM: windows-zfs GUID: 101_321aa67a-2aa2-45f5-b6f2-a7f1a8e0d821 Host: pve3
VM: wintest3-nfs GUID: 105_7a3e58d8-be9e-4e03-a040-bd1635aa3dfe Host: pve3
Datastore List:
Datastore Name: ontap Total Size: 65,536 Free Space: 2,924,216,320
Datastore Name: cephpool Total Size: 3,025,732,826 Free Space: 4,075,159,552
Datastore Name: local-zfs Total Size: 4,165,549,440 Free Space: 1,031,267,056
Datastore Name: iscsivol Total Size: 4,290,772,992 Free Space: 4,290,772,992
Datastore Name: iSCSI Total Size: 0 Free Space: 0
Network List:
Network Name:[vmbr1]
Network Name:[vmbr0]
Host=[pve2] Version=[]
VM: wintest4 GUID: 106_912c2649-d3bd-4fcb-99d4-0e58d52fba85 Host: pve2
Datastore List:
Datastore Name: local-zfs Total Size: 3,871,536,496 Free Space: 3,765,379,120
Datastore Name: ontap Total Size: 65,536 Free Space: 2,924,281,856
Network List:
Host=[pve1] Version=[]
VM: linux1 GUID: 100_ebbfefd1-8fb0-4661-97b3-e9365eabdfd3 Host: pve1
VM: wintest2 GUID: 104_8a4b0fa4-6406-4daa-926b-b1c118799d2c Host: pve1
VM: wintest1 GUID: 102_9458ccf3-2723-4529-b0eb-0ff008f2d8af Host: pve1
Datastore List:
Datastore Name: local-zfs Total Size: 3,859,675,152 Free Space: 1,241,192,096
Network List:
exited
root@pve3:~# /opt/commvault/Base64/TestVMInfo -proxmox -server localhost -user root -password <password> -getdsinfo
localhost 8.3.5
Datastore List:
Datastore Name: local-zfs Total Size: 4,165,653,104 Free Space: 1,031,228,864
Datastore Name: local-zfs Total Size: 3,871,492,848 Free Space: 3,765,335,472
Datastore Name: local-zfs Total Size: 3,859,653,328 Free Space: 1,241,170,272
exited
root@pve3:~#
virtualmachine on NFS share information
root@pve3:~# /opt/commvault/Base64/TestVMInfo -proxmox -server localhost -user root -password <password> -fullmount  -vmname wintest3-nfs -readdisks
localhost 8.3.5
Found VM wintest3-nfs with Guid 105_7a3e58d8-be9e-4e03-a040-bd1635aa3dfe on host pve3
-- Testing Full Mount --
VMName: wintest3-nfs VMGuid: 105_7a3e58d8-be9e-4e03-a040-bd1635aa3dfe
MountPath: /opt/commvault/Base/Temp/VMMount JobResults: /opt/commvault/Base/Temp/VMJobResults
Mounting [wintest3-nfs].....
MountVM failed for [wintest3-nfs]!!
MountVM Failed - [23] Error opening the virtual machine disks.
exited
/var/log/commvault/Log_Files/TestVMInfo.log
root@pve3:~# tail -f /var/log/commvault/Log_Files/TestVMInfo.log
572611 8bcc3 04/16 11:22:15 ### skipFS::SetFSCacheEnabled(542) - FSType cache is enabled
572611 8bcc3 04/16 11:22:15 ### EvEvent::SetupConnectionWithCVD() - Loading library under Base32
572611 8bcc3 04/16 11:22:15 ### EvEvent::SetupConnectionWithCVD() - Loading library under Base64
572611 8bcc3 04/16 11:22:15 ### main() - ================ Test VM Info Started =============================
572611 8bcc3 04/16 11:22:15 ### main() - Test VM Info BUILD-TIME=[02:16:28] BUILD-DATE=[Mar 15 2025]
572611 8bcc3 04/16 11:22:16 ### CProxmoxInfo::Connect() - Connecting to Url=[localhost] User=[root]
572611 8bcc3 04/16 11:22:16 ### ProxmoxSDKWrapper::CProxmoxWrapper::Connect() - Connected to [localhost] Version [8.3.5]
572611 8bcc3 04/16 11:22:16 ### CProxmoxStorageCfg::LoadStorageInfo() - Invalid storage info
572611 8bcc3 04/16 11:22:16 ### CProxmoxInfo::_MountVM() - Mounting VM:[wintest3-nfs] with GUID:[105_7a3e58d8-be9e-4e03-a040-bd1635aa3dfe]
572611 8bcc3 04/16 11:22:16 ### ProxmoxSDKWrapper::CProxmoxWrapper::FindAndFillVMInfoFromCache() - Found [3] VMs on node [pve3]
572611 8bcc3 04/16 11:22:16 ### CProxmoxInfo::_MountVM() - Creating Snapshot [GX_BACKUP_0] of VM [wintest3-nfs]
572611 8bcc3 04/16 11:22:19 ### CProxmoxInfo::SaveVMConfigFile() - Wrote vm config file successfully to [/opt/commvault/Base/Temp/VMMount/vmConfig.json]
572611 8bcc3 04/16 11:22:19 ### CProxmoxInfo::MountVM_Disks() - Connecting to VM [wintest3-nfs] snapshot [GX_BACKUP_0] for disk access
572611 8bcc3 04/16 11:22:19 ### CProxmoxInfo::MountVM_Disks() - Opening disk [ontap:105/vm-105-disk-0.qcow2]
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd1] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd1, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd2] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd2, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd3] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd3, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd4] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd4, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd5] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd5, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd6] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd6, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd7] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd7, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd8] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd8, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd9] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd9, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd10] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd10, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd11] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd11, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd12] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd12, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd13] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd13, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd14] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd14, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd15] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd15, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd16] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd16, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd17] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd17, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd18] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd18, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd19] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd19, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd20] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd20, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd21] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd21, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd22] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd22, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd23] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd23, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd24] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd24, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd25] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd25, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd26] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd26, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd27] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd27, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd28] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd28, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd29] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd29, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd30] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd30, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd31] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd31, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd32] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd32, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd33] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd33, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd34] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd34, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd35] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd35, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd36] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd36, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd37] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd37, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd38] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd38, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd39] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd39, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd40] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd40, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd41] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd41, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd42] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd42, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd43] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd43, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd44] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd44, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd45] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd45, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd46] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd46, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd47] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd47, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd48] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd48, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd49] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd49, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd50] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd50, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd51] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd51, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd52] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd52, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd53] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd53, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd54] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd54, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd55] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd55, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd56] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd56, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd57] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd57, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd58] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd58, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd59] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd59, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd60] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd60, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd61] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd61, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd62] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd62, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd63] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd63, OperationFlag=0x0, PermissionMode=0x0}
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::BuildMountCommand() - Failed to get NBD device
572611 8bcc3 04/16 11:22:19 ### CProxmoxDiskInfo::_OpenDisk() - Failed to build mount command for disk [105/vm-105-disk-0.qcow2] storage [ontap]
572611 8bcc3 04/16 11:22:19 ### CProxmoxInfo::MountVM_Disks() - Failed to open disk [ontap:105/vm-105-disk-0.qcow2]
572611 8bcc3 04/16 11:22:19 ### CProxmoxInfo::MountVM_Disks() - Unable to open any disks on VM [wintest3-nfs]
572611 8bcc3 04/16 11:22:19 ### CProxmoxInfo::UnmountVM() - Deleting Snapshot [GX_BACKUP_0] of VM [wintest3-nfs]
572611 8bcc3 04/16 11:22:20 ### HandleVMInfoError() - MountVM Failed - [23] Error opening the virtual machine disks.
572611 8bcc3 04/16 11:22:20 ### DumpConnectionMap - handle count = 0, map count = 0
Best answer by Bert1961
I have a working configuration.
Proxmox VE v8.4.1 3 node cluster
Netapp NFS datasres (Ontap 9.15.p7)
CommVault v11.36.53
After the installation of the vsa (virtual Server Agent) on the proxmox hosts,
The backup gave me the error “can’t connect to te VM disk file” in the log files the error “Failed to open device [/dev/nbdXX] “
In the log file i saw that qemu-nbd tries to mount a snapshot from the vm’s to backup and fails.
Using the command “ modprobe nbd” on all hosts creates de devices needed in /dev/nbdxx
And the backup and restore works.
Add the line nbd on /etc/modules to make the module load by every boot.
Onno van den Berg
Forum|alt.badge.img+24
Sounds like a possible permission issue. Given the fact that NFS support was added in MR49 and that Proxmox is still very new from a Commvault perspective so I would definitely open a support ticket. You could try to enroll MR52 that was released earlier this week, but the release notes do not mention anything for Proxmox, but that doesn't say it might contain a fix.
In this time, I was evaluting proxmox backup, not have license
I want to try next update MR52.
  • April 25, 2025
Same error here, with 11.36.49 and Proxmox VE 8.4.0 in combination with NetApp NFS Datastores.
Onno van den Berg
Can you reinstall the Commvault agents on the access node with 11.36.41 and try to see if it works again? ​@osakanataro can you share an update if MR52 addressed your issue and if you opened a support ticket for it?
I tried to upgrade from 11.36.49 to 11.36.52… failed same error
uninstall 11.36.52 and re-install 11.36.52, but failed.
We have a 3 node proxmox cluster for our POC and NetApp NFS datastores.
With v11.36.52 all backups failed.
We install 11.36.53 and we could make full/incremental backups.from VM’s on server POC01.
From VM’s located on servers POC02 and POC03 all the backups fails.
Migrate these VM’s to POC01 and the backups are succesfull.
When the backup fails we see in de job log file that the agent tries to connect to a nbd device.
/dev/nbd0 to /dev/nbd63
As far as I now:
Network block devices (NBD) are used to access remote storage device that does not physically reside in the local machine.
In the directory /dev/ there are not any nbd devices defined, and we are using NFS datastores, it seems the agent is trying to access te vM’s using the wrong storage type.
1974431 1e20b4 05/01 12:43:07 1952760 CProxmoxInfo::MountVM_Disks() - Connecting to VM [windowstest2022test2] snapshot [GX_BACKUP_1952760] for disk access
1974431 1e20b4 05/01 12:43:07 1952760 CProxmoxInfo::MountVM_Disks() - Opening disk [POC_SSD_F59_DS003:102/vm-102-disk-0.qcow2]
1974431 1e20b4 05/01 12:43:07 1952760 CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd1] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd1, OperationFlag=0x0, PermissionMode=0x0}
1974431 1e20b4 05/01 12:43:07 1952760 CProxmoxDiskInfo::GetDeviceSize() - Failed to open device [/dev/nbd63] - 0xECCC0002:{CQiFile::Open(95)} + {CQiUTFOSAPI::open(87)/ErrNo.2.(No such file or directory)-Open failed, File=/dev/nbd63, OperationFlag=0x0, PermissionMode=0x0}
1974431 1e20b4 05/01 12:43:07 1952760 CProxmoxDiskInfo::BuildMountCommand() - Failed to get NBD device
1974431 1e20b4 05/01 12:43:07 1952760 CProxmoxDiskInfo::_OpenDisk() - Failed to build mount command for disk [102/vm-102-disk-0.qcow2] storage [POC_SSD_F59_DS003]
1974431 1e20b4 05/01 12:43:07 1952760 CProxmoxInfo::MountVM_Disks() - Failed to open disk [POC_SSD_F59_DS003:102/vm-102-disk-0.qcow2]
1974431 1e20b4 05/01 12:43:07 1952760 CProxmoxInfo::MountVM_Disks() - Unable to open any disks on VM [windowstest2022test2]
1974431 1e20b4 05/01 12:43:07 1952760 CProxmoxInfo::UnmountVM() - Deleting Snapshot [GX_BACKUP_1952760] of VM [windowstest2022test2]
  • May 6, 2025
CommVault v11.36.53
​@Bert1961 thanks information.
I tried execute “modprobe nbd”, then successfull!
root@pve3:~# lsmod|grep nbd
root@pve3:~# modprobe nbd
nbd 65536 0
root@pve3:~# /opt/commvault/Base64/TestVMInfo -proxmox -server pve3 -user root -password password -readdisks -vmname linux2-ceph
pve3 8.4.1
Found VM linux2-ceph with Guid 103_37f0d81e-3ed1-417a-9a10-3d8f556e3b37 on host pve3
VMName: linux2-ceph VMGuid: 103_37f0d81e-3ed1-417a-9a10-3d8f556e3b37
Mounting [linux2-ceph].....
Mount done for [linux2-ceph].
Name: linux2-ceph Uuid: 103_37f0d81e-3ed1-417a-9a10-3d8f556e3b37
Host: pve3 Version:
Tools: GuestOS: Linux 2.6 - 6.X Kernel
Cleanup String: GX_BACKUP_0
File: linux2-ceph.json 540.00 B
Disk: cephpool:vm-103-disk-0 40.00 GB 40.00 GB
1 disks Used Size: 40.00 GB Provisioned Size: 40.00 GB
Opening disk vm-103-disk-0
Reading disk vm-103-disk-0
Read 42,950,721,536 bytes in 01:48 40961 samples from vm-103-disk-0
376.60 MB/Sec
1323.99 GB/hr
Closing disk vm-103-disk-0
VM [linux2-ceph] Total Read 42,950,721,536 bytes in 01:48
376.55 MB/Sec
1323.80 GB/hr
Unmounting linux2-ceph
Unmount done for linux2-ceph
exited
root@pve3:~#
