PRoxmox VE livesync
  • April 27, 2026
  • 92 views
Livesync est il possible entre deux proxmox VE?
Best answer by Pradeep
Hi ​@PROXMOX VE ,
VM replication between Proxmox VE devices, this is not provided by Commvault LiveSync. You would need to use Proxmox's native replication features or other third-party tools for that purpose.
We can follow below steps.
  • Back up VMs from a Proxmox VE cluster using the Virtual Server Agent (VSA).
  • Restore VMs or guest files from backup to the same or another Proxmox VE environment.
  • Use Commvault's backup and restore workflows for disaster recovery, but not real-time or near-real-time VM replication between Proxmox clusters.
https://documentation.commvault.com/11.40/software/protecting_proxmox_ve_vms_with_commvault.html
  • April 28, 2026
Hi ​@PROXMOX VE ,
Sureshkumar S
HI ​@PROXMOX VE ,
Good day!
Also our team is working on enabling auto recovery support for proxmox.
Unfortunately we dont have an ETA on this support
Until then you can use steps provided by ​@Pradeep
Sureshkumar S
