re-register client agent with commserve
  • October 21, 2021
  • 4772 views
Forum|alt.badge.img+2
We are backing up VMWare VMs using image level backup. These VM have client file system iDA installed to backup NFS and RDM LUNs which are mapped to VMs.
We have performed the restore of one of the VM in test environment with different name, to restore the files & folders into the RDM LUN we want to register the client agent with the Commserve with new hostname without re-installing the agent.
Is there a way to achieve this?
PS: We are not using IntelliSnap feature.
Best answer by MichaelCapon
Hi @Jaspreet ,
Once you’ve changed the hostname of the client, I suspect that you might be able to register with the CS using the Fetch Method or SimCallWrapper. - Refer to the following link for the details on these methods: https://documentation.commvault.com/11.24/expert/2092_registering_client_computers.html
Let me know how you get on.
Michael
MichaelCapon
  • October 21, 2021
Hi @Jaspreet ,
Michael
  • October 29, 2021
Hello @MichaelCapon ,
Thanks for your response and sorry for my late reply.
I have tried with both the methods but it doesn’t work. I am getting below message when I try to fetch the details from CommServe Console
and following error when I try to using SIMCallWrapper method and commvault -all status output.
Please let me know if you want any specific logs.
I have the same problem and when I try to register the client, can you tell me how you solved it?
