Recall from S3 Glacier
  • June 30, 2022
  • 109 views
Got below error when I recall data from S3 glacier. We don’t have chance to disable digital sign on PS, any workround?
Error Code: [19:857]
Description: File E:\Program Files\Commvault\ContentStore2\Base\Temp\script_7d7ec2dce69ceae6.ps1 cannot be loaded. The file E:\Program Files\Commvault\ContentStore2\Base\Temp\script_7d7ec2dce69ceae6.ps1 is not digitally signed. You cannot run this script on the current system. For more information about running scripts and setting execution policy, see about_Execution_Policies at https:/go.microsoft.com/fwlink/?LinkID=135170. + CategoryInfo : SecurityError: (:) [], ParentContainsErrorRecordException + FullyQualifiedErrorId : UnauthorizedAccess
Source: vaw-wpc-001, Process: Workflow
Best answer by Mike Struening
Sharing case solution:
Solution:
Dev provided diag update "v11SP24_Available_Diag5286_WinX64" which fixed the issue.
The official hotfix is included in V11SP24.59.
Underlying Cause:
Commvault (Configuration and Product)
Secondary Cause:
Product Change - Hotfix/Feature Release/SP
Patch ID, Script, Service Pack, or MR#:
V11SP24.59
Hi @xiwen !  Hope all is well!
I was able to find only 2 incidents with this error, and BOTH went to development to address.
Can you open a support case and share the incident number here for tracking?
  • July 4, 2022
I opened CV case: : 220704-7
Solution:
Underlying Cause:
Secondary Cause:
V11SP24.59
