Redhat 8.* file level recovery
  • February 27, 2023
  • 130 views
Forum|alt.badge.img+9
Can HSX nodes running with RedHat 7.9 can be used as FREL for Linux VM’s running RedHat8.* ?
I know it is not working for us on version 11.28.24. Is it supported on higher versions ?
  • February 27, 2023
In order to browse File Level for RHEL/CentOS 8, the FREL will also need to be running RHEL/CentOS 8. This is due to changes in the filesystem.
  • February 27, 2023
Thanks @NVFD411
Is it relevant only for XFS ?
Looks like the FREL (RedHat 7.9)  can brwose EXT4 of RedHat 8.3 VM
