Restore from SnapVault Error
  • May 23, 2022
  • 212 views
Error
I get the above error when try to restore from secondary snap volume. May i know why it cant get snapshot information stored in DB at first place?
Best answer by Jos Meijer
Hi @Raj Balaraj
A few questions:
  • Are you able to find and mount the snapshot manually via array management?
  • Can you recover from other snapshots/snapshot tiers?
  • Are other operations working as expected when using this media agent?
  • is FC zoning is in place to perform the mount?
  • Can you communicate with the array control host to initiate the mount?
  • May 23, 2022
Live browser have this error
Jos Meijer
Forum|alt.badge.img+21
  • Community All Star
  • May 23, 2022
Hi @Raj Balaraj
A few questions:
  • May 23, 2022
Hi @Jos Meijer
i believe it is because the FC zoning. the SVM newly created and did not done any zoning to host yet.
we cant discover/add any LUN from the SVM also.
    Answer: cannot
    Answer: from snapshot yes. snapvault cannot.
  • Answer: Yes
    Answer: not yet
    Answer: yes. able to open / browse from cluster and svm level.
    Next Action: i will contact the network team to done the Zoning. Thanks.
