Restore Virtual Access Node
  • Nov 27, 2024 3:17 AM UTC
  • 82 views
Hi All,
Is there any way I can restore full virtual machine to a virtual access node if it is only access node in particular VMware environment. Because all Commvault services on this access node don’t start up after upgrading its software version to 11.32.69.
Thank you.
Best answer by Rajiv
Hello ​@Andy Nguyen Can you check for space on /opt by running df -kh and make sure you have enough space? Push update had failed I believe, and this would need repair/re-installation of commvault software on this client.
Rajiv
  • Nov 27, 2024 9:24 AM UTC
Hello ​@Andy Nguyen Did the upgrade completed successfully and asked for a reboot to complete the install? Also, the Auto-start services when OS starts option in process manager under services, checked?
Best,
Rajiv Singal
  • Nov 28, 2024 1:33 AM UTC
Hi Rajiv, I did the upgrade using CommServe server not locally on the VSA proxy node. From Job Control screen it states upgrade “Failed” because no response from client. When login to VSA node, I see only cvdfw service is running, the rest is stopped (this is Linux client not Windows) even after reboot. Manually starting cvd service then I got below error:
Rajiv
  • Nov 28, 2024 7:44 AM UTC
  • Dec 2, 2024 12:15 AM UTC
Thanks Rajiv, it has been fixed by manually re-install the package.
