Restored out of place VM not visible in Azure Portal
Forum|alt.badge.img+2
I’m trying to get our Azure local POC added into Commvault. I’m able to backup VMs and can restore out of place VMs but the restored VMs are not viewable in Azure Portal. Is there a time delay in synchronization? The restored VMs were viewable in Windows Admin Center.
Clayton
  • May 27, 2025
It seems the Azure local VMs were restored as Hyper-V VMs (is this expected?). I noticed the following note in Azure Portal:
“This may not be the full list of VMs on this Azure Local instance. Only Arc VMs created through the Arc Resource Bridge appear here.”
Is this why the restored VM is not listed? Is there a way to make the restored VMs visible in the Portal?
Hi Clay,
Your theory sounds plausible. Azure local is Azure HCI which is built on Hyper-V technology, so it isn’t unreasonable that it identifies the VM as Hyper-V and Commvault does not restore using ARB as that’s used for image deployment.
You mentioned that the restore was done out-of-place, was it out of place back to the Azure local cluster (but renamed or relocated)?
I am curious if the view filters the restored VM because it wasn’t created through the ARB. I don’t have an Azure local instance to test but I would recommend seeing if there is a way to view non-ARB VMs in the local portal. It may also help to contact Azure support to see if Azure Local, non-ARB VMs can be viewed through the portal.
  • May 29, 2025
Hi Jace,
The restore was out-of-place back to the cluster and renamed. I think the concern is that since the VM is not viewable in Azure Portal and is restored as a Hyper-V VM, it would also lose the hybrid benefits.
I suppose an in-place restore is what Commvault would recommend.
Clayton
