Use Ansible to deploy FREL OVA
  • October 6, 2021
  • 438 views
Juergen
Explorer
I am running CommVault V11SP20.55.
I want to deploy FREL servers with Ansible  but I do not found the keyword to change the root password during installation, this the playbook which I use:
If anyone can help my will be great, or do have anyone the initial password which is in the OVA configured?
thanks in advance
regards Jürgen
Best answer by Gopinath
Hi Juergen,
Try using keyword ‘bcRootPassword’ for ‘New password for 'root'’ for ova deploying FREL client. we can also check these on existing FREL which got deployed already. See if this helps.
Regards
Gopinath
Forum|alt.badge.img+8
  • October 6, 2021
Hi Juergen,
Regards
Gopinath
Juergen
Explorer
  • October 7, 2021
Hello @Gopinath ,
That was exactly what i am looking for, thanks a lot.
best regards Jürgen
