Virtual Lab functionality
  • March 3, 2022
  • 1029 views
I would like to covers about problem with Commvault.
The problem concerns the configuration of the Virtual Lab functionality.
When attempting to configure a policy, Commvault will not be able to "see" CV_VLAB_GATEWAY or any network configured in the VMware environment. Such a machine is in the client's Vmware environment.
I will be very appreciate for help
Best answer by Alireza B
Hi, Have you tried to download the template from Commvault store?
If you want to create a gateway computer that allows communication with
computers outside of the virtual lab, you must download the V11 CV VLab Gateway Template - VMware that is compatible with your service pack from the Commvault Store, import it into vCenter, and convert it into a template.
For download instructions, see Downloading Items from Commvault Store.
Important: You must name all virtual machine templates using this format: CV_VLAB_GATEWAY_*. Only templates that begin with this prefix are displayed.
https://documentation.commvault.com/commvault/v11_sp16/article?p=33029.htm
Alireza B
  • March 4, 2022
