Virtual Machine Guest Files Restoration Steps are Very Slow
  • Jan 8, 2025 7:57 AM UTC
  • 12 replies
  • 215 views
We are facing a issue with gust files restoration steps getting too much time after 95 % to take the Disk drivers page. Some time error occur for something went wrong. what is the possible cause of this issue.
Hi ​@Dasun Jayaweera ,
Is this Windows or Linux?
Is this V1 or V2 Indexing?
Is this from Primary or Secondary?
As it can be anything, I would recommend you log a case with COmmvault Support so we can review.
Sebastien
This is Windows Virtual Machine, Storage is primary, about indexing version I don’t have any idea. I already created support ticket but there are mention this is regarding to performance issue but we monitored resource utilization there are no any overutilization.
What is your TR I can check?
TR means ?
Your Trouble Report, Ticket Number?
Ticket Number is # 250106-193
ok, will review.
Any update anyone?
​@Dasun Jayaweera ,
I am confused, this is what your TR says:
Thanks for answering the call.
Since there is no active/pending troubleshooting required from CV end at this time and you will be further checking with the end user on the suggested, As discussed and agreed, I'm setting this ticket and under ‘Closure Pending’ and the case will be automatically closed at 5 PM IST on this Monday if no further issues observed.
We cannot do any server spec upgrade because there are no any utilization and also they requested 96 GB ram that’s not possible, Unfortunately customer end these days have some kind of power failure because of that we cannot do any configurations from our end that’s the main issue.
You can reopen the case within 48h and explain the same.
I have reviewed the logs, it seems that the Disk/Media are really slow:
                 Pipeline read speed: 0.60462707436663243 MB/s
                 Pipeline read speed: 0.47212324504187353 MB/s
                 Pipeline read speed: 0.58893666382044785 MB/s
                 Pipeline read speed: 0.46877270932757326 MB/s
                 Pipeline read speed: 0.48069852519600875 MB/s
Can you check and confirm with them?
If so, can they use faster storage media?
