VM backup issue
  • September 26, 2022
  • 620 views
Forum|alt.badge.img+2
Error Code: [82:156] Description: The job is pending because: The destination encountered an error while processing the data from the source. Source: com-v, Process: CVD
Best answer by Gil S
Hi @Abhiman W ,
Have there been any recent Commvault software updates to your Commserve or media agents and or vsa proxies? You might want to check that the media agents and vsa proxies are on the same Commvault Software Version level as your Commserve.
this issue happen running on backup.
Forum|alt.badge.img+5
Hi Abhiman,
Have you checked this KB?  https://kb.commvault.com/article/77418
  • September 27, 2022
Good Morning @Abhiman W ,
Additional details on the true error may be found from the proxy performing the backup.
We might need the following logs to review the first steps.
  1. CVD.log
  2. VSBKP.LOG
  3. CVFWD.LOG
  4. VixDiskLib.log
additional logs or a TR may be required but it would be a start.
Hi @Abhiman W ,
