VM with SQL backup
  • November 22, 2021
  • 136 views
When backing up VM (on VMWare) with SQL, event log is filled with error:
The device, \Device\Harddisk4\ ……. is not ready for access yet.
At this moment only IntelliSnap is enabled and under Backup Options, File system and application consistent backup selected.
Any suggestions?
Best answer by MichaelCapon
Hi @TSunsLV ,
Since you are performing a Quiesced backup (File system and application consistent), You may encounter Event ID 15 inside the VM.
See VMware Article: https://kb.vmware.com/s/article/85148
Unless you’re having issues with the Guest VM, I believe this error can be ignored.
Michael
MichaelCapon
  • November 22, 2021
Hi @TSunsLV ,
Michael
