VMware protection and Transparent Snapshot
  • Jul 8, 2024 1:53 PM UTC
  • 299 views
Robert Horowski
Some time ago Dell introduced support for Transparent Snapshots in their offerings which according to their materials should boost VMware VMs protection and restore. As far as I know Dell is the only vendor using this, so I am not sure whether this is a VMware technology or is it a third-party in this case.
Anyhow, I wanted to ask if there is a similar solution on the road ahead that is/will be available in Commvault?
Hello @Robert Horowski
Transparent Snapshots is a feature created and used by the Dell backup solution.
In support we cannot comment on the road map and when/if new features will be added into the product but know Commvault is always one step ahead and treats being competitive seriously.
Kind regards
Albert Williams
Kind regards
Albert Williams
Robert Horowski
  • Community All Star
  • Jul 9, 2024 7:46 AM UTC
Hello @Albert Williams
I work with Commvault for some time and I can generally agree that *usually* Commvault is one step ahead. This time though, unless there is some new feature enhancing VMware protection that I missed, I would argue 😊
What I really miss is better communication from Commvault about new features and planned changes. This could be really helpful when talking to customers about new opportunities. I hope that it will change some day.
Thanks, and have a great day!
Forum|alt.badge.img+2
  • Dec 1, 2024 10:21 PM UTC
Hello guys
Transparent Snapshots, is a feature introduced with Dell PowerProtect Data Manager, following an agreements with VMware. After Dell sold VMware to Broadcom several deals fell through, and commvault could also benefit from the feature (use of vSphere API for I/O (VAIO) Filtering framework).
Kind Regards
Gianluca
Onno van den Berg
Forum|alt.badge.img+24
I don't expect Commvault is going to waste development time to add support for transparant snapshots because if you move away from VMFS to vVols it will already take a way the performance constraints related to traditional snapshots and this is definitely the better route as it not only benefits backup and recovery processes.
