VSA Guest Customization
  • December 21, 2021
  • 939 views
Forum|alt.badge.img+8
Hi, When I install the Virtualization package on a client, I now have the option to also select “VSA Guest Customization” (so not only the Virtual Server Agent). What is this option used for?
Thank you.
Best answer by Gopinath
That package needed for guest customization in continuous replication.
https://documentation.commvault.com/11.24/essential/125618_continuous_replication_group_options_for_vmware.html
To customize IP address settings for continuous replication, the VSA Guest Customization package must be installed on the VSA access node.
Regards
Gopinath
  • December 21, 2021
Regards
Gopinath
  • Certified Expert
  • December 21, 2021
Thanks! When I searched for “VSA Guest Customization” in BOL, this page didn't show up. I should have put it between brackets.
