VSA VM client has two backup sets
  • May 17, 2024 12:59 PM UTC
  • 34 views
Forum|alt.badge.img+9
VM was migrated to different vCenter, now it has two BackupSets old and new.
Could you say please how to remove old one?
clecky
Forum|alt.badge.img+13
  • May 17, 2024 3:08 PM UTC
I’m just guessing here but that most likely references the backupset on the original vcenter pseudo client.
Which I suspect means it won’t go anywhere until that other vcenter is deleted.
You can test it renaming the backupset on the old vcenter pseudo client that discovered this client.
  • May 20, 2024 7:12 AM UTC
It definitely points to old vCenter client as I see old subclient inside pointing to old storage policy. We don’t plan to remove old vCenter and I would bet that you will not be able to do that while you have references to VMs (child objects).
