Why SAN transport mode is only supported for proxies on physical computers ?
  • September 29, 2021
  • 1544 views
We are planning to change the setting of our current Commvault Server transport mode from Network to SAN based.
However, when I check the manual, it says the SAN transport mode must a physical Server as the Proxy Server to back VMs
The fact is, we have been using Netbackup environments at somewhere else for years where the master / Media Servers doing VM backups are Virtual Machines but with HBA cards directly presented to them, so that all the datastores are visible to them.
So, I’m just wondering why many backup software vendors (like Commvault) don’t support the configuration of using a Virtual Machine as the backup host for SAN (transport mode) backup VMs ?
Kelvin
Best answer by Aplynx
CommVault is using VMware’s VDDK to run the backups. These are VMware requirements, which is why CommVault, Veritas, Veem, etc all say the same thing.
If you need to use a virtual machine, then HotAdd would be the available option. Both physical and virtual can use NBD, but that would typically be the slowest option as it would be over the network.
Aplynx
  • September 30, 2021
Hi Aplynx,
I’m just wondering, for this VDDK, which I know is the most common reason to fail SAN transport,
  1. Why it works on a physical Server then ?
  2. Can we just download the VDDK from VMware and install it on a Virtual VMware host ?
Cheers,
Kelvin
https://www.veritas.com/support/en_US/article.100030882
Veritas also mentions for san mode physical server is needed.
https://vdc-repo.vmware.com/vmwb-repository/dcr-public/17aee92f-6920-4675-b03c-8c85de455bb3/eb0d4676-c916-484a-b7e8-138a867db8a6/doc/vddkDataStruct.5.5.html
VMware also mentions it.
Why do you want to install the VDDK in a guest machine? If you want to use CommVault, install the VSA agent on a physical or virtual proxy and VDDK is embedded already.
Aplynx
These are VMware requirements.
Does anybody know why VMware doesn’t support VMware backup host on a Virtual Machine ?
The reason why I ask this is, we have been using a VM Netbackup Server with HBA directly passing through to it, to SAN backup our VMs for many years, which seems to be fine. And now, we want to deploy the same design to US Commvault environment…
Kelvin
