Api documentation for 11.40
  • August 12, 2025
  • 111 views
Forum|alt.badge.img+9
I see that the api.commvault.com has not been updated with information about SP40.
Latest version to be selected is SP38
Does this mean that api-documentation for 11.38 is the one to use for 11.40, or has it just not been published yet?
Planning an upgrade to 11.40 and wants to make sure if there is any changes to the API’s I’m currently using, to ensure a smooth transition.
Best answer by Jon Vengust
Hi John,
Correct, API documentation for 11.40 will largely remain the same and can be referenced in the meantime. I will look to consult our internal teams regarding when our documentation will reflect 11.40.
Jon Vengust
  • August 13, 2025
Hi John,
