API that returns which node uses current node as Access Node
  • Feb 21, 2025 9:54 AM UTC
  • 80 views
In CC ( Protect → File Servers → <item>-->tab Configuration (down&left) a list of servers that use current node as Access Node is displayed. I would like to get this list using an API, but I am not able to find the API.
Is there an API that provides this info ?
Thanks in advance !!
Best answer by MaheshPrakash
https://cchostname/commandcenter/api/Client/58551?propertyLevel=15&accessNodeInfo=true
Below is the object to look for on the response
pseudoclients:
pseudoclients:
