Cannot open sandbox
  • January 20, 2025
  • 142 views
Forum|alt.badge.img+8
Hi All,
I am not able to open a sandbox on CommServe. Blank page is displayed only.
Sandbox URL is https://commserveFQDN/webconsole/sandbox/
Dev tools in the browser (F12) writes: “Error with Permissions-Policy header: Parse of permissions policy failed because of errors reported by structured header parser.”
Trying to open with Microsoft Edge.
Repairing the instance has not solved the issue.
The https://commserveFQDN/webconsole/sandbox/apiexlorer URL is working.
Any ideas?
Thank you,
Lubos
UPDATE: The REST Webservice API Sandbox page finally showed up after more than half an hour :-O
Best answer by Lubos Dvorak
It takes long time to open the sandbox if the Commserve has no internet connectivity.
  • January 21, 2025
Hi ​@Lubos Dvorak ,
Restart the IIS and tomcat service on the webserver machine and try re opening Sand Box URL.
If the issue still remains same, review webserver logs to understand failures.
  • June 20, 2025
