Command to change the container of tape media
  • Jan 12, 2025 8:09 AM UTC
  • 109 views
I’m looking for a command to change the container of a tape media.
In the CommandCenter it’s not possible to change the container and therefore I can’t find an equivalent API.
In the Console I’m able to change the container of a tape but even if I activated logging (ALT-F8) there was nothing useful in the logs.
I was searching through documentation but found no qcommand or anything to change the container.
Best answer by Marc St.
I opened a Case and the answer was:
...development just got back to me regarding this. We unfortunately do not have an API call for this option as of now ...
Hey ​@Marc St.
The only thing I know about tapes and containers is associated with vault tracker - is this what you mean? there is a CLI utility for that but I can’t say I’ve done anything with it.
Hope that helps:
https://documentation.commvault.com/2024e/expert/qmodify_container.html
  • Jan 19, 2025 11:48 AM UTC
Hey ​@Marc St.
Hope that helps:
Hi Damian,
Thank you for your input.
With this command I can modify a container, but I can’t assign a tape to a container.
I found another command to change the location of a tape, but the location is already used by the vault tracker policies and it should not be overwritten.
  • Mar 11, 2025 2:12 PM UTC
