Creation Authtoken and accepting it
  • Feb 27, 2024 3:21 PM UTC
  • 85 views
Forum|alt.badge.img+13
Hi Team,
I'm very new to the Rest API, but I was only able to create an authtoken :) As far as I learned, when the authtoken is created, the max. It can be used for 30 days. After this period, it is necessary to create a new authtoken and use the new authtoken. We are thinking something like this, Is it possible to do this?
We are trying to create a powershell script, this script will create a new authtoken every time it runs and will automatically use the new authtoken, then we will be able to GET the information we want from Commvault. Rest
Best answer by Justin Glass
Timeout is defaulted to 30 minutes. You’ll want to create a token for minutes in 30 days by adding timeout to the body of your request.
Login | Commvault®
  • timeout integer
    Default value: 30
    Timeout of the token in minutes
Forum|alt.badge.img+2
  • Feb 27, 2024 6:07 PM UTC
Login | Commvault®
  • timeout integer
    Default value: 30
