How Commvault integrate with a customized SOAR platform?
  • September 23, 2024
  • 88 views
Experts, when sometimes the customer rely on a customized third party orchestration platforms like SIEM and SOAR platforms that specialize in security incident response.not the standard SOAR platforms we integrated with.  Is there any guide for showing how our platform integrates with the customized SOAR or SIEM tools and provides the similar incident response and orchestration abilities? thanks in advance.
Best answer by Javier
Hi Jason,
Did you check the documentation about SIEM integration?
https://documentation.commvault.com/2023e/essential/siem_connector.html
I think this might be what you are looking for?
  • September 25, 2024
Hi Jason,
